Normal Topic Bug switching between TreeLayouts (Read 2024 times)
jaschwa
Mar 8th, 2007 at 12:38pm
I found a funky bug that occurs in the WinForms and the NetDiagram component (pre-beta) when you switch between a Bordered Top-To-Bottom Table layout with Rounded Arrows to a Centralized Left-to-right Table layout with Perpendicular-2 Arrows. The Nodes get positioned like you'd expect for a Centralized Left-To-Right layout, but the arrows stay rounded with their control points don't move; only the end points. The results is a loopy, scribbly looking layout.
Try it in the FCDemo.exe. Not that you'd normally switch from one layout to another in the normal course of viewing a diagram, but still, it does seem like a bug.
Jeff Schwandt&&Corporate Net Solutions&&Fidelity National Financial&&Jacksonville, FL&&
Re: Bug switching between TreeLayouts
Reply #1 - Mar 8th, 2007 at 12:53pm
Yes, the Cascading2 arrow style is intended for use only with the Bordered tree layout. We haven't found a way to arrange 2-segment arrows in a centered tree and make the layout look good, so the algorithm just ignores that combination.
