Normal Topic add control point nd change location (Read 1231 times)
alesdario
Mar 8th, 2007 at 1:51pm
i promise that this is the last time i ask you a question!
I've two last doubt.
First: how can i add a control point to bezier arrow?
Second: is there a method who allow me to change location of a Box after i create them?
TANKS!!
Re: add control point nd change location
Reply #1 - Mar 8th, 2007 at 2:34pm
Please do not hesitate to ask questions at any time 8)
Unfortunately you cannot add a single point to the Bezier arrow. You can only add a whole segment, which is three additional points. That will also reset the control point coordinates, so you might need to save the old ControlPoints values, and restore them after adding the segment.
You can use the Move method or the BoundingRect property to change the box location.
