Normal Topic text and image of a box. (Read 1876 times)
pcone
Mar 9th, 2007 at 9:06am
hi.
I've fit box' property text and image. But i need that the text of the box is displaied at the bottom of the box, under the image. Is it possible? How?
tanks.
Re: text and image of a box.
Reply #1 - Mar 9th, 2007 at 10:17am
You could set the ImageAlign property to TopCenter and the TextFormat.LineAlignment to Far. That still does not guarantee that the text and image won't overlap - it depends on the image size. If there is some overlapping, try defining a new ShapeTemplate instance where the ImageRectangle and TextArea are set, e.g. the ImageRectangle to cover the upper 80% of the box, and the TextArea the bottom 20%. Then display the image using the Fit or Stretch alignment, and it should not cover the text.
pcone
Reply #2 - Mar 9th, 2007 at 12:39pm
Very tenks. But now i have this problem.
How can i set Image Rectangle and Text area. When i create a new ShapeTemplete istance i set:
Box.Shape = new ShapeTemplate(
  new ElementTemplate[]
     new LineTemplate(.....)
     in this part of code i think that i will
     insert code about decorations,the Image i     suppose.
     here i must insert LineTemplate for textArea.
   FillMode,ID)
If the code is correct, i ask you:
How can i set ImageRectangle and TextArea?
Very, very, very Tanks.
Reply #3 - Mar 9th, 2007 at 1:21pm
Here is some smaple code:
private void Form1_Load(object sender, System.EventArgs e)
	ElementTemplate[] textRect = new ElementTemplate[]
		new LineTemplate(0, 80, 100, 80),
		new LineTemplate(100, 80, 100, 100),
		new LineTemplate(100, 100, 0, 100),
		new LineTemplate(0, 100, 0, 80)
	ShapeTemplate myshape = new ShapeTemplate(
		ShapeTemplate.FromId("Rectangle").Outline, null, textRect, FillMode.Winding, "myshape");
	myshape.ImageRectangle = new RectangleF(0, 0, 100, 80);
	Box test = fc.CreateBox(0, 0, 100, 100);
	test.Style = BoxStyle.Shape;
	test.Shape = myshape;
	test.Image = Image.FromFile(@"D:\Images\1.jpg");
	test.ImageAlign = ImageAlign.Fit;
	test.Text = "myshape test";
