Normal Topic Transparent Images and Alignment (Read 1347 times)
jstraylor
Mar 13th, 2007 at 12:01pm
We are having a minor problem with a PNG that has a transparent color set and it's alignment in a box.
What we are trying to do is use the box background color as the fill color for our PNG, so we use something like
box.fillcolor = color.red
box.image = image.fromfile("image.png")
box.imagealign = imagealign.stretch
And what happens is that we sometimes get a line of 1 (or less) pixel around the outside edge of the PNG that is placed on the box.  I have tweaked the box.pen.width to .25, but beyond that it starts to encroach on the image that we are showing.
Is there any way to force a "full fit" of the image to the box??  As an alternative, do I need to play with the image size and box size to make sure that the size ratios are exactly the same??
I can post the png image itself and box sizes if needed.
Jeff
Re: Transparent Images and Alignment
Reply #1 - Mar 13th, 2007 at 12:21pm
Could you send me the image and a screenshot showing the problem?
Thank you,
jstraylor
Reply #2 - Mar 16th, 2007 at 2:13pm
Just posting the solution for anyone else who encounters a similar problem.
> That looks like some rounding error in the Graphics.DrawImage method, to
> > which we pass the Box.BoundingRect when drawing a stretched image. For
now,
> > try setting a slightly larger ImageRectangle in the ShapeTemlpate used
with
> > that box, e.g. (0, 0, 100.01, 100.01).
Works like a champ.
Jeff
