Normal Topic Property TriggerRerouting (Read 1179 times)
alesdario
Mar 13th, 2007 at 1:25pm
Hi.
I set the property
FlowChart.RoutingOptions.TriggerRerouting = WhenIntersectNode, but arrow will always rerouted, even tought in the flowchart there are only two boxes. Why?
Re: Property TriggerRerouting
Reply #1 - Mar 13th, 2007 at 1:43pm
That property is checked only after you drag a control point of an arrow. The arrow is always rerouted if you move its origin or destination boxes. You might disable AutoRoute and call the arrow's Route() method from some event handlers if you need routing to be done only in some specific situations.
