Normal Topic How to turn off hotspots (Read 4018 times)
wyang
Mar 14th, 2007 at 1:05am
How do I turn off hotspots?
Re: How to turn off hotspots
Reply #1 - Mar 14th, 2007 at 4:32am
If by "hotspots" you mean selection handles, you can set HandleStyle = Invisible or Locked = true. If you mean anchor points - set Node.AnchorPattern = null.
Reply #2 - Mar 14th, 2007 at 4:33am
... and if you need to disable individual selection handles, clear their respective flags in the EnabledHandles property.
wyang
Reply #3 - Mar 14th, 2007 at 9:52pm
What I mean by "Hotspots" is actually the hyperlink associated to all diagrams in the flowchart.
How do I turn those hyperlinks off?
I tried to set the hyperlink = string.empty, but the hyperlink will interpret that as the home page link.
Reply #4 - Mar 15th, 2007 at 5:11am
The HtmlBuilder doesn't create image map area for a node whose Hyperlink is set to the empty string "". But I think that older versions of the control created areas even for empty hyperlinks - which FlowChart.NET version do you have? You might still be able to stop the hyperlink from going to the home page by setting it to "javascript:void".
wyang
Reply #5 - Mar 15th, 2007 at 7:58pm
Yeah, tried "Javascript: void" but the hyperlinks are still active. When I clicked the hyperlink, it is not going to homepage but giving me a javascript error.
What I want is actually disable those hyperlinks so the user can't click on anything. The user can only view the flowchart.
Reply #6 - Mar 16th, 2007 at 5:07am
If you do not need hyperlinks at all, simply don't create an image map - remove all references to the HtmlBuilder.
The correct syntax to disable individual hyperlinks is "javascript: void(0)"; that works fine only if the HtmlBuilder.LinkTarget is "_self".
wyang
Reply #7 - Mar 18th, 2007 at 8:54pm
I need to create an image map so that the flowchart can be displayed in the website.
Is there any other way to do that besides creating image map?
Reply #8 - Mar 19th, 2007 at 8:46am
You can copy the code related to image generation from the WebApp example - e.g. adding an IMG tag, setting its URL to ImageGen.aspx and sending the image data from the ImageGen page to the browser. Just leave out the parts related to generating the client side image map - i.e. do not use the HtmlBuilder to add a MAP tag and do not add an USEMAP attribute to the IMG tag.
