Normal Topic Method Intersect (Read 2243 times)
pcone
Method Intersect
Mar 14th, 2007 at 7:22am
Hi.
I use the method
Arrow.Intersect(Arrow.Origin) and return always true, also when the arrow don't cross trought the box Arrow.Origin.
Why?
Re: Method Intersect
Reply #1 - Mar 14th, 2007 at 8:29am
I guess the one common pixel between the arrow and its origin node is enough for Intersects to return true. If you need to know whether the arrow crosses its origin, try using a temporary box slightly smaller (say 0.5mm) than the origin and call Intersects for it.
pcone
Reply #2 - Mar 14th, 2007 at 10:45am
Is there e method who delete a Box after i create it?
i use this method:
public bool Intersect(Arrow a, Box b)
Box temp;
temp = this.flow.CreateBox((b.BoundingRect.X)+1,(b.BoundingRect.Y)+1,(b.BoundingRect.Size.Width - 2 ),(b.BoundingRect.Size.Height - 2));
return a.Intersects(temp);
this.flow.DeleteObject((Box)temp);
but box still remain on the flow chart.
Reply #3 - Mar 14th, 2007 at 12:05pm
The function returns before DeleteObject executes -
pcone
Reply #4 - Mar 14th, 2007 at 12:26pm
Sorry, i didn't notice!
