Normal Topic Locking All Arrows (Read 2173 times)
Wonderkid
Locking All Arrows
Mar 14th, 2007 at 12:43pm
We have recently purchased FlowChartX Pro to replace treeview in our workflow functions.
I have one sticking point at present: The arrows on our chart are selectable (at some point during development this has changed) and when they are selected, the ickle square boxes are shown... and if the arrow has segments, you can currently move the ickle square boxes in the middle. You know the scenario I mean, I'm sure.
Anyway, I had thought that setting ArrowSelStyle to 0 would mean that all arrows are 'unselectable'. If so, this is being ignored.
Is there a method of going through all arrows in a flow chart and locking them? (We are using Progresss OpenEdge 10).
Many Thanks for any help!
EDIT - On reading this, I just want to make sure that we don't care if the arrow is actually being selected or not as long as the appearance doesn't change and nothing can be moved. On out chart, we don't want anything to be drawn or moved and only want boxes 'selectable'.
Re: Locking All Arrows
Reply #1 - Mar 14th, 2007 at 1:36pm
Setting Arrow.Locked = true for all arrows will make them unselectable.
Wonderkid
Reply #2 - Mar 15th, 2007 at 6:19am
Thanks for your reply!
After using CreateArrow, I now use the following and it works like a charm Cheesy
flowcharthandle:ActiveArrow:locked = true.
