Normal Topic ZIndex (Read 1589 times)
nikulin_andrey
ZIndex
Mar 16th, 2007 at 2:35pm
Hi all,
I have a box box1 and several boxes inside of box1.
I have called box1.ZBottom() and for boxes inside box1 - ZTop() methods. But when I select box1 - it covers boxes inside it.
How to handle it?
Re: ZIndex
Reply #1 - Mar 16th, 2007 at 4:19pm
Setting SelectionOnTop = false should help you with that.
areddan
Re: ZIndex
Reply #2 - Mar 19th, 2009 at 4:41am
On this topic, I have disabled SelectionOnTop, and manually call ZTop when a node is selected (if I don't, when users try to drag the node it just selects whatever has a higher index).
Problem with this is, it doesn't seem to propogate to items attached to the node. I just want to call "ZTop" on the group basically.
Cheers,
Anthony
Re: ZIndex
Reply #3 - Mar 19th, 2009 at 8:47am
Hi Anthony,
Call ZTop on the node and then on each attached node. You can access the attached nodes using the SubordinateGroup.AttachedNodes collection.
