(UTC)
Welcome, Guest. Please
Login
or
Register
News:
Board Index
Help
Search
Login
Register
The MindFusion Forums
Flow Diagramming Components
Windows Forms
› ZIndex
(Moderator: Slavcho)
Previous Topic
Next Topic
Pages: 1
Send Topic
Print
ZIndex (Read 1677 times)
nikulin_andrey
st
, 2006
ZIndex
Mar 16
th
, 2007 at 2:35pm
Hi all,
I have a box box1 and several boxes inside of box1.
I have called box1.ZBottom() and for boxes inside box1 - ZTop() methods. But when I select box1 - it covers boxes inside it.
How to handle it?
th
, 2005
Re: ZIndex
Reply #1 -
Mar 16
th
, 2007 at 4:19pm
Setting SelectionOnTop = false should help you with that.
areddan
th
, 2009
Re: ZIndex
Reply #2 -
Mar 19
th
, 2009 at 4:41am
On this topic, I have disabled SelectionOnTop, and manually call ZTop when a node is selected (if I don't, when users try to drag the node it just selects whatever has a higher index).
Problem with this is, it doesn't seem to propogate to items attached to the node. I just want to call "ZTop" on the group basically.
Cheers,
Anthony
th
, 2005
Re: ZIndex
Reply #3 -
Mar 19
th
, 2009 at 8:47am
Hi Anthony,
Call ZTop on the node and then on each attached node. You can access the attached nodes using the SubordinateGroup.AttachedNodes collection.
Pages: 1
Send Topic
Print
Previous Topic
Next Topic
Forum Jump »
Board Index
» 10 most recent Posts
» 10 most recent Topics
General
News
Discussion
News
Feature Suggestions
Windows Forms ««
WPF
Html Canvas & JavaScript
WinUI 3
Blazor
ASP.NET MVC
ASP.NET
Java Swing
ActiveX
.NET MAUI and Xamarin
Android
Cocoa Touch
Bug Reports
Scheduling and Gantt Components
News
Feature Suggestions
Windows Forms
WPF
ASP.NET
Html & JavaScript
Java Swing
Bug Reports
Gauge and Chart Components
News
Feature Suggestions
Windows Forms
WPF
Blazor
ASP.NET
Java Swing
Bug Reports
Grid and Spreadsheet Components
News
Feature Suggestions
Windows Forms
WPF
Html & JavaScript
Java Swing
Bug Reports
Virtual Keyboard Components
News
Windows Forms
WPF
Avalonia
Java Swing
Html & JavaScript
Bug Reports
MindFusion.Reporting
News
Feature Suggestions
Windows Forms
WPF
Silverlight
Bug Reports
MindFusion.UI controls
Windows Forms
WPF
ASP.NET
Other MindFusion tools
News
Feature Suggestions
Discussion
Bug Reports
Archived Boards
Silverlight
.NET Compact Framework
Silverlight
Silverlight
« Board Index
‹ Board
» Powered by
YaBB 2.6.11
YaBB Forum Software
© 2000-2025. All Rights Reserved.
