Normal Topic "Split" an existing arrow into two new a (Read 1989 times)
mattapayne
Mar 20th, 2007 at 3:59pm
More fun with arrows!
Here's the scenario:
I need to allow a user to "split" an arrow - in other words, to select an arrow and cut it in half, effectively creating 2 new arrows joined at the separation point by a new Box.
This is simple in the case of a single segmented arrow, but I'm having trouble in the case of an arrow that has multiple segments where the user has created a shape. In this case I need to split it at the midpoint, but maintain the original shape.
So far I've had awesome help from this forum. I'm hoping that this is a doable scenario.
Matt
Re: "Split" an existing arrow into two n
Reply #1 - Mar 20th, 2007 at 6:21pm
You might implement that by saving the control point positions for the original arrow, and assigning them back to the control points of the new arrows, e.g.
private void splitAt(Arrow arrow, short segment, PointF point)
	if (arrow.Style == ArrowStyle.Polyline)
		PointCollection points = arrow.ControlPoints.Clone();
		Box box = fc.CreateBox(point.X - 2, point.Y - 2, 4, 4);
		Arrow newArrow = fc.CreateArrow(box, arrow.Destination);
		arrow.Destination = box;
		arrow.SegmentCount = (short)(segment + 1);
		newArrow.SegmentCount = (short)(arrow.SegmentCount - segment);
		for (int i = 0; i < arrow.ControlPoints.Count - 1; ++i)
			arrow.ControlPoints[i] = points[i];
		arrow.UpdateFromPoints();
		for (int i = segment + 1; i < points.Count; ++i)
			newArrow.ControlPoints[i - segment] = points[i];
		newArrow.UpdateFromPoints();
mattapayne
Reply #2 - Mar 20th, 2007 at 6:45pm
Yeah, that's kind of what I was going for. I had created two new arrows and removed the old one, but I guess I could always just keep the old one and only create a single new one, then just reassign the control points.
Thanks as always.
Matt
Reply #3 - Mar 21st, 2007 at 5:05am
In case anyone needs to get the segment index from the point coordinates - it is returned through an output parameter by one of the GetArrowAt overloaded methods.
