Normal Topic Size of cell (Read 1170 times)
alesdario
Size of cell
Mar 22nd, 2007 at 7:16am
Hi stoyo
i've got a problem with event CellBoundChanged.
The cell i will modify contains one or more box.
Whan i tighten the cell i must verify that the greater distance i can move is the difference
beetwen top border of the cell and the top border of the highest box
I calculate this distance. Next, i calculate difference beetwen NewBounds.Bottom and OldBounds.Bottom.
If this difference is greater than the first difference, i would set:
NewBounds.Bottom = OldBounds.Bottom but Build action write me that it is not possible due the read-only properti of NewBounds.Bottom.
There is a wai to do this?
Thanks for your excellent support
Re: Size of cell
Reply #1 - Mar 22nd, 2007 at 11:29am
You could set the height of the row that contains the cell. Use GetCellRow() to get the index of the row, then set grid.RowHeaders[index].Height. That might raise the CellBoundsChanged event again - use some boolean flag to prevent reentrancy.
