Normal Topic fitsizetotext sometimes hangs (Read 5358 times)
chrise
Mar 27th, 2007 at 10:55am
I have found that resizing a box using fitsizetotext can hang if the text is less one character.
I have also found that fitsizetotext also hangs if the text box is manually resized and then fitsizetotext is called.  This mainly happens if the box is larger in vertical direction.
We resize the text using the option keepheight.
Re: fitsizetotext sometimes hangs
Reply #1 - Mar 27th, 2007 at 11:11am
What do you mean by "text is less one character"?  an empty string?
Thank you,
chrise
Reply #2 - Mar 27th, 2007 at 11:18am
Sorry.  I mean empty or a single character.  This is easy to code round.  However it's not so easy on the other one with a large box.
Reply #3 - Mar 27th, 2007 at 11:33am
one more question - do you use styled text and/or polygonal text layout?
chrise
Reply #4 - Mar 27th, 2007 at 11:39am
Both are set to false.
chrise
Reply #5 - Mar 27th, 2007 at 11:41am
I have set PolyTextLayout to true and it is working fine now.
Reply #6 - Mar 27th, 2007 at 11:49am
Thank you, we can reproduce that with an empty string. Could you also post the text and coordinates for the manually resized box?
chrise
Reply #7 - Mar 27th, 2007 at 12:06pm
Text :    wewef
X:         17.5
Y:         7.5
Width:   15
Height:  45
Fontsize:           8.25
Fontstyle:          bold
Fontname:         Tahoma
Fontunit:           point
Fontheight:        14
Sizeinpoints:     8.25
Hope this helps.
Reply #8 - Mar 29th, 2007 at 10:31am
This should be fixed now. If anyone needs the updated dlls urgently, please contact us by email. Or as a workaround temporarily enable PolyTextLayout before calling the FitToText(KeepHeight) method.
