Normal Topic Several Questions (Read 1784 times)
mjweyland
Several Questions
Apr 2nd, 2007 at 1:56pm
I have several questions, if this is best split out to separate posts just let me know and I can split them out.
Question 1.  How do I prevent a flowchart box from making recursive arrows?  Initially I wanted to trap this on the arrowcreating event of the flowchart but without knowing the destination box of the arrow this is not trappable.  I then added code to the arrowcreated event and am removing it from the arrows collection but the arrow is still showing on the form.
Question 2:
How would one clone a flowchart to be able to add it to a tab control with all of the events and their respective methods available to the newly created flowchart control?
Any help on this would be greatly appreciated.
Re: Several Questions
Reply #1 - Apr 2nd, 2007 at 2:11pm
1. Set FlowChart.AllowRefLinks = false.
2. You can clone the flowchart properties by calling fc1.LoadFromString(fc2.SaveToString()). You will need to manually attach the event handlers to the second flowchart though...
mjweyland
Reply #2 - Apr 2nd, 2007 at 2:22pm
Thanks!!  This is what I was looking for.
Can you clarify a little on the how I would manually attach event handlers to the second flowchart?
secondly, I am still having an issue when the arrow is removed from the flowcharts arrows collection that it still visible on the flowchart.  How do I visibly remove the arrow from the flow chart in addition to removing it from the arrows collection.
Thanks again for your prompt response.
Reply #3 - Apr 2nd, 2007 at 3:10pm
Assuming you use C#, you can copy the relevant code from the form's InitializeComponent method. For each event that you handle, VS adds a
flowchart.EventName += handlerMethod;
statement to InitializeComponent. Copy all these statements to a new method, pass the flowchart object as a parameter, and call the method for each new flowchart that the application creates.
You can call FlowChart.DeleteObject to remove an arrow. That will remove the arrow from FlowChart.Arrows and FlowChart.Objects, and will create an undo/redo record for the operation.
