Normal Topic Fit Size to Text (Read 3844 times)
pelion
Fit Size to Text
Apr 5th, 2007 at 3:47am
Hi, I am creating a box as a text holder label for another image box, with the text length being variable. My problem is that the FitSizeToText just doesn't seem to do anything, and my text is constantly been truncated.
If there is a reason my code below can't work, how can I get the length of a string as compared to a box size to set it myself?
(I also don't want it to be wrapping on spaces, just all one line)
private Box CreateTextBox(FlowChart chart, PointF pointf, string ImageText)
//Create Box
Box box = chart.CreateBox(pointf.X - 16, pointf.Y + 8, 10, 8);
box.FrameColor = Color.Black;
//box.IgnoreLayout = true;
//box.EnableStyledText = true;
box.HandlesStyle = HandlesStyle.InvisibleMove;
box.Font = new Font("Tahoma", 3f, GraphicsUnit.World);
box.Text = ImageText;
box.FitSizeToText(FitSize.KeepHeight);
box.Locked = true;
box.Transparent = true;
//Handle Style
box.FrameColor = Color.Gray;
return box;
Re: Fit Size to Text
Reply #1 - Apr 5th, 2007 at 5:07am
Are there new-line characters in the string? If there are some, there might not be enough space to fit the text in the fixed height and the method just returns false.
rand_acs
Reply #2 - Apr 5th, 2007 at 8:25am
I have a problem that is the opposite. How to fit text to size.
I have a shape that has an image rectangle and a text area under it. The text string can become quite long. It gets truncated when to long and words that are to long for the box width also has the same effect.
I can't let the icons change size, so I can't use the FitSizeToText function. Is there any way of getting the text to format better?
And another question. What would be the best way of uniquely identifying the boxes already created by the FlowChart class?
Reply #3 - Apr 5th, 2007 at 10:52am
If you attach another box to the icon and use it as a label, you could call the label's FitSizeToText. That way the icon won't be resized, but just the label box below it. Or you might create a temporary box, get its size after calling FitToText, and apply that size to the ShapeTemplate' text area.
You could use the Box.ZIndex to identify a box. There aren't any two boxes with the same ZIndex, and the following dependence is always true: fc.Objects[aBox.ZIndex] == aBox. You might also assign some GUID to the Box.Tag and use fc.FindBox() to get the box that corresponds to a GUID.
sambalmueslie
Reply #4 - Apr 12th, 2007 at 6:12am
How works this "attach"? Is it possible to use one Box which contains two shapes. One for the Image and one for the Text?
Or is it possible to resize the Shape back to its "normal" size after doing the FitSizeToText.
Thanks, Oli
Reply #5 - Apr 12th, 2007 at 6:35am
The attached box will follow the master box when the latter is moved or resized. This will create a composite shape that contains one box for the image and another for the text:
string imagePath = @"D:\Images\1.jpg";
Box icon = new Box(fc);
icon.Image = Image.FromFile(imagePath);
icon.FitSizeToImage();
icon.Transparent = true;
fc.Add(icon);
Box label = new Box(fc);
label.Text = "label text";
label.BoundingRect = new RectangleF(PointF.Empty,
	fc.MeasureString(label.Text, label.Font, int.MaxValue, label.TextFormat));
label.Transparent = true;
label.Locked = true;
fc.Add(label);
// attach the label to the icon
RectangleF rc1 = icon.BoundingRect;
RectangleF rc2 = label.BoundingRect;
	rc1.Left + rc1.Width / 2 - rc2.Width / 2,
	rc1.Bottom + 1,
	rc2.Width, rc2.Height);
label.AttachTo(icon, AttachToNode.BottomCenter);
sambalmueslie
Reply #6 - Apr 12th, 2007 at 10:14am
thank you for the answer.
But I still have two problems. First one is, that the Text  on the Label changes later. Its possible to change it. But the Label doesn't resize. It has still the size from the beginning. I try to resize the BoundingRect but I don't know how.
And the second Problem is, that the TextLabel remains when the Icon will be deleted. How can I fix this.
Oli
Reply #7 - Apr 12th, 2007 at 10:22am
After calling label.AttachTo(icon), set icon.SubordinateGroup.AutoDeleteItems = true.
You could use the same code as above to set the label.BoundingRect again. I.e. first call Box.FitSizeToText or Box.BoundingRect = fc.MeasureString(). That will set the correct size, but won't keep the label aligned to the horizontal center of the icon. To align the label to the icon, set the BoundingRect in the same way as before calling label.AttachTo. There is no need to call AttachTo again.
