Normal Topic Images in table rows (Read 1224 times)
mozzis
Apr 9th, 2007 at 11:49pm
I have downloaded FC.Net 4.3 demo and am writing a program using C# in Visual Studio 2005.
When I assign an image to a table, the ImageAlign setting works as expected.
When I assign an image to a table cell, Images always are smaller than the table cell and aligned on the left hand side.
Is this by design?
[code]
Bitmap bmp = new Bitmap(strIconName, false);
Table item = new Table(_diagram);
item.Caption = strClassName;
item.Image = bmp;
item.ImageAlign = ImageAlign.Stretch;
_diagram.Add(item, true);
[/code]
[img]http://www.mza.com/~morris/fcnetq2.png[/img]
[code]
item.RedimTable(1, 2);
item[0, 1].Text = "";
item[0, 1].Image = bmp;
item[0, 1].ImageAlign = ImageAlign.Stretch;
[/code]
[img]http://www.mza.com/~morris/fcnetq1.png[/img]
Re: Images in table rows
Reply #1 - Apr 10th, 2007 at 3:12am
It seems the only column in the table has smaller width than the table itself. That cannot be seen from the image because the control never draws the right borders for the right-most cells. You can fix the alignment problem by setting
table.Columns[0].ColumnStyle = ColumnStyle.AutoWidth;
