Normal Topic How to place big pieces to the top? (Read 4121 times)
maron.mar
Apr 10th, 2007 at 10:39am
Hi
I am developing a windows application in which it contains a pie chart. I am showing
the data from a database. For this i am using a datatable.
now i want to place the big pieces at the top and the smaller ones - to the bottom.
I am not sure how to do that.
Re: How to place big pieces to the top?
Reply #1 - Apr 10th, 2007 at 1:52pm
Is your data sorted? If it is, you could set the StartAngle to one that will bring the largest pieces to the top. It seems the bar and line charts have a SortOrder property, but it is not available in the pie chart yet, so you will need to sort the values yourself  Undecided
maron.mar
Reply #2 - Apr 11th, 2007 at 10:33am
Thanks Stoyo,
I sorted manually the data,  no problems with that.  I put the large piece to the top, looks o.k.
