Normal Topic [Resolved] DragDrop an arrow object ? (Read 2093 times)
belfaigore
Life is so wonderfull
Apr 12th, 2007 at 8:31am
I have an explorer object of link, and I would like user to be able to drag and drop an arrow and only after set the Start/End connection.
Dim MyArrow As New Arrow(MyFlowChart)
MyFlowChart.Add(MyArrow)
When I try this code, nothing append on my flowchart
« Last Edit: Apr 12th, 2007 at 10:52am by belfaigore »
Re: DragDrop an arrow object ?
Reply #1 - Apr 12th, 2007 at 8:41am
Again you might have to use "new DummyNode()" as arrow's origin and destination, or otherwise the control won't display the arrow. Or call the FlowChart.CreateArrow(PointF, PointF) method which will create the nodes for you.
belfaigore
Reply #2 - Apr 12th, 2007 at 10:07am
I try create my arrow with DummyNode like that :
Dim MyArrow as new Arrow(MyArrowPrototype, New DummyNode(MyFlowChart),New DummyNode(MyFlowChart))
But it's the same, nothing append on the flowchart
Reply #3 - Apr 12th, 2007 at 10:12am
Have you tried setting the Arrow.ControlPoints coordinates to ones in the visible area? The default might be (0,0) for all points, and you won't see the arrow then.
belfaigore
Reply #4 - Apr 12th, 2007 at 10:51am
ok, it work it was the property I need (ControlPoints). thanks a lot
