Normal Topic lane grid (Read 1802 times)
thgr
lane grid
Apr 13th, 2007 at 6:19am
In a lane grid i try to change the color of a cell
and to attach a table in another.
In both cases it changes tha color of the cell to Black And it shows the table i create in the cell Black too.
Any idea what i'm doing wrong?
Re: lane grid
Reply #1 - Apr 13th, 2007 at 7:01am
What code do you use in order to change the color of the cell and create the table?
thgr
Re: lane grid
Reply #2 - Apr 13th, 2007 at 7:11am
       Dim _grid As Grid = Me.theGraph.LaneGrid
       _grid.ColumnCount = 3
       _grid.RowCount = 3
       _grid.GetRow(1).Height = 80
       _grid.GetRow(0).Height = 80
       _grid.GetRow(2).Height = 80
       _grid.GetColumn(0).Width = 80
       _grid.GetColumn(1).Width = 80
       _grid.GetColumn(2).Width = 80
       Dim a As New MindFusion.Diagramming.WinForms.Lanes.Style
       _grid.HookHeaders = False
       '        _grid.HeadersOnTop = False
       a.BackgroundBrush = New MindFusion.Drawing.SolidBrush(KnownColor.Violet)
       _grid(1, 2).Style = a
       _MASTER_NOTE_X_COOR = _grid.GetCellBounds(_grid(1, 1)).Location.X
       _MASTER_NOTE_Y_COOR = _grid.GetCellBounds(_grid(1, 1)).Location.Y
       _ENTRY_MASTER_X_COOR = _ENTRY_MASTER_X_COOR - 20
       _ENTRY_MASTER_Y_COOR = _ENTRY_MASTER_Y_COOR - 10
  For Each _note As NoteProxy In theModel.AllNodesQ
  ' Creates a table and Adds the table in a cell
           If _note.EntryGID.Equals(CType(theModel.MasterNote, NoteProxy).EntryGID) Then
               CreateMasterNote(_note)
           End If
       Next
       Me.theGraph.EnableLanes = True
Re: lane grid
Reply #3 - Apr 13th, 2007 at 12:57pm
For some reason this code compiles under VB, although the MindFusion.Drawing.SolidBrush constructor does not accept parameter of type KnownColor. I assume that VB performs some kind of implicit conversions between the KnownColor enumeration and Color. Try the following substitution instead:
a.BackgroundBrush = New MindFusion.Drawing.SolidBrush(Color.FromKnownColor(KnownColor.Violet))
Check the same when applying a brush to the table objects you are using.
