Normal Topic Control appears to freeze on post back. (Read 4541 times)
Steven_Elliott
Apr 13th, 2007 at 8:59am
I have found the NetDiagram control to be excellent so far and have had no problems working the with the sample projects. However when trying to use it in a real world project I have had a problem with the post back.
My ASP.NET 2.0 project features Master Pages, a sitemap and and the Ajax.Net Update Panel in the Master Page for the content.
In a simple page consisting of a FlowChart and an asp.net button control, when the button is clicked the content of the flowchart dissappears including scroll bars and the control no longer responds to user interaction. Only when I click on the button again does the diagram repear and the control respond to interaction.
Does any one have any ideas?
Steven Elliott
Re: Control appears to freeze on post back.
Reply #1 - Apr 13th, 2007 at 9:31am
Thank you for letting us know about this problem. Does it happen when using the applet mode, or the image-map one? and is the flowchart instance placed inside an Update Panel?
Steven_Elliott
Reply #2 - Apr 13th, 2007 at 9:36am
This happens in Applet Mode. Update Panel is in the master page. The Update Panel contains a content place holder in which the page containing the Flowchart appears.
Many thanks.
Steven
Reply #3 - Apr 13th, 2007 at 11:09am
It seems the client side scripts that initialize the applet are not executed after UpdatePanel postbacks. We will try to find some work-around in the next few days.
Steven_Elliott
Reply #4 - Apr 13th, 2007 at 11:12am
Thank you for your reply. I am happy to know I am not going mad Smiley
I look forward to your work-around.
Many thanks
Steven Elliott
Reply #5 - Apr 26th, 2007 at 12:30pm
Could you check if this version of the dll works any better with the UpdatePanel in your page?
https://www.mindfusion.org/_temp/NetDiagram.dll.zip
