Normal Topic How to get the ActiveX proposition? (Read 3897 times)
foucault
Apr 16th, 2007 at 5:49am
I'm currently evaluating the FlowChartX component for use in html pages, exactly as we can see in your online demo.
When the clients go on your online demo, it asks to install an ActiveX control. When they go on mine, they have a mistake. So I would like to know what I exactly have to do in my code to get the ActiveX proposition.
My application is written in vb.net and I'm using IE 6.
Re: How to get the ActiveX proposition?
Reply #1 - Apr 16th, 2007 at 6:29am
You must create a CAB file that installs the control and specify its URL in the CODEBASE attribute of the OBJECT tag. Have you done that?
In addition, the CAB for our online demo is digitally signed and IE will run it under stricter security settings. We can build a signed CAB for you if you don't have your own digital signature.
foucault
Reply #2 - Apr 16th, 2007 at 7:43am
I'm a total newbie concerning ActiveX controls, so no, I didn't create my CAB file. I searched a little bit how to do, but I didn't get concrete results.
I would be grateful if you can provide me a CAB file  Smiley
Reply #3 - Apr 16th, 2007 at 9:25am
Sure - do you need one for the Pro or the standard edition?
foucault
Reply #4 - Apr 16th, 2007 at 9:40am
A pro one please
Reply #5 - Apr 16th, 2007 at 10:10am
http://www.mindfusion.org/_temp/fcx_pro_trial.CAB
The Pro version has a different CLSID than the standard one. If you have copied the OBJECT tag from the online demo, you will need to change he ID there to {F025BF4E-4081-4c02-86E6-6602AEE846F6}.
foucault
Reply #6 - Apr 16th, 2007 at 10:21am
Wonderful ! It perfectly worked, thanks a lot.
