Normal Topic Keep the changes between client and server? (Read 3766 times)
foucault
Apr 18th, 2007 at 8:16am
Hello again, sorry to ask you so much things
I have an other problem :
I'm using the component in a web application.
On the client side, the user modifies the diagram, so I update the hiddenfield each time he draws something :
Sub fcx_DocModified()
  form1.HiddenField1.Value = form1.fcx.SaveToString(True)
    end Sub
I have a button which authorize the user to export to xml. The matter is that the page is reload, so on the server side, I try to get the value of the hidden field :
myflowChart.LoadFromString(HiddenField1.Value)
but it raises an error : Error HRESULT E_FAIL has been returned from a call to a COM component.
So, I would like to know if it's possible to get, on the server side, the modifications done by the user on the client side?
Re: Keep the changes between client and server?
Reply #1 - Apr 18th, 2007 at 9:00am
That should work. Is there anything in the HiddenField1.Value that you get on the server?
foucault
Reply #2 - Apr 18th, 2007 at 10:29am
Yes, HiddenField1.value has a huge huge string. Weirdly, I can't print it in a msgbox (probably because of the size) but I arrived to do it on the client side
Here you can see the client side:
http://img68.imageshack.us/my.php?image=hiddenfieldclientli8.jpg
Here you can see the beginning of the value of hiddenfield1.value on the server side
http://img222.imageshack.us/img222/8802/hidedenfieldvalueld8.jpg
But I'm unable to use it in a msgbox, so I think that's why it cannot be used with the LoadFromString
Reply #3 - Apr 18th, 2007 at 11:16am
Could you save the string into a file and email it to support@mindfusion.eu? We'll check if it contains a correct value that FlowchartX can load.
foucault
Reply #4 - Apr 18th, 2007 at 11:44am
It's not necessary, I finally understood my error : Sooner, to try something else, a collegue adds a reference to the flowchart 3.0 library. When I changed it to 4.1, it works immediately.
Reply #5 - Apr 18th, 2007 at 11:52am
Right - old versions of the control can't load files or strings saved with a newer version.
