Normal Topic Size of control point of Boxes and Arrows (Read 1352 times)
alesdario
Apr 18th, 2007 at 12:15pm
Hi.
Is there a way to increase size of control points of arrows and boxes?
I try to set
flow.ArrowIntermSize = 12F;
to increase arrows' control point size but i didn't obtain any results.
To increase Boxes' control point i've not got any idea. Sad
Tanks
Re: Size of control point of Boxes and Arrows
Reply #1 - Apr 18th, 2007 at 12:23pm
You can use the FlowChart.SelHandleSize property to do that. It is a global setting for all objects in the diagram.
alesdario
Reply #2 - Apr 18th, 2007 at 12:34pm
OK  Smiley . Your solution is perfect!
Tanks for your excellent support.
