Normal Topic [RESOLVED] Auto snap created arrow on input anchor (Read 3129 times)
belfaigore
Life is so wonderfull
Apr 20th, 2007 at 10:11am
I have a box "box1" with an anchor pattern wich contain Output AnchorPoints, and a second box "box2" with another anchor pattern wich contain one input anchor point.
My flowChart behavior property is set to "CreateArrow", and when I create an arrow from my Box1 to my Box2, the arrow doesn't automaticly snap to input AnchorPoint but is snap to position of the mouse on the box2 when creation end.
How can I do to automaticaly snap arrow end to input anchorpoint ?
« Last Edit: Apr 20th, 2007 at 12:05pm by belfaigore »
Re: Automaticaly snap creating arrow on input anch
Reply #1 - Apr 20th, 2007 at 10:43am
Could you post here the code that initializes the anchor points? Do you by any chance handle the ValidateAnchorPoint event?
belfaigore
Reply #2 - Apr 20th, 2007 at 10:49am
I don't handle the ValidateAnchorPoint event
Here is my code that générate the AnchorPattern for my component
	  ''' <summary>
	  ''' Cette fonction permet de retourner les point d'ancrage de l'objet
	  ''' </summary>
	  ''' <remarks></remarks>
	  Public Function GetAnchorPattern() As MindFusion.Diagramming.WinForms.AnchorPattern
		' Définie les point d'ancrage (Pourcentage)
		Dim Points As New AnchorPattern
		With Points.Points
		    .Clear()
		    ' Entrèe du Capteur : Entrée
		    Dim Point As New AnchorPoint(0, 50)
		    With Point
			  .AllowIncoming = True
			  .AllowOutgoing = False
			  .Color = _AnchorPoint_CaptorMarkColor
			  .MarkStyle = _AnchorPoint_CaptorMarkStyle
			  .ToolTip = "Entrée capteur"
			  .Tag = "Entrée"
		    End With
		    .Add(Point)
		    Point = Nothing
		    ' Sortie du Capteur : Sortie
		    Point = New AnchorPoint(100, 50)
		    With Point
			  .AllowIncoming = False
			  .AllowOutgoing = True
			  .Color = _AnchorPoint_OutputMarkColor
			  .MarkStyle = _AnchorPoint_OutputMarkStyle
			  .ToolTip = "Sortie du capteur"
			  .Tag = "Sortie"
		    End With
		    .Add(Point)
		    Point = Nothing
		End With
		Return Points
	  End Function
and after
Dim Table As New Table(MyFlowChart)
Table.AnchorPattern = GetAnchorPattern()
Reply #3 - Apr 20th, 2007 at 10:58am
Thank you, and what is the Table.LinkStyle?
belfaigore
Reply #4 - Apr 20th, 2007 at 11:40am
I don't know for what this property is used, the value can be "Rows", "Table" or "Both".
I'll tryed to set the different value but nothing append on runtime.
I Know the FlowChart property "SnapToAnchor" wich is set to "OnCreatedOrModify" but the correct behavior is apply only to my Box component and not to the table component
Reply #5 - Apr 20th, 2007 at 11:49am
If an arrow links to a table's row, which is the case when LinkStyle is Rows or Both, the control uses the points from Table.RowAnchorPattern. So try assigning your points to that property.
belfaigore
Reply #6 - Apr 20th, 2007 at 12:04pm
Thanks a lot, it solve my trouble.
