Normal Topic generating FlowChartDiagramm from SQL-Data (Read 4154 times)
Dunkelelb
Apr 24th, 2007 at 12:10pm
hello,
I got a SQL-Table with some entries belonging state and connection informations in several columns.
I already importet the nodes. Now I'd like to organize
the connections. Have you some hints which way I should choose to reach that?
thanks
Re: generating FlowChartDiagramm from SQL-Data
Reply #1 - Apr 24th, 2007 at 12:41pm
Do you ask how to import the connections, or how to arrange the diagram once they are imported?
In order to create the connections, you might assign the node ID in the database to the Box.Tag property. Run a second loop over the node records, and for each related node ID you have for a node, call CreateArrow(node, FlowChart.FindBox(relatedID)). If you already use the Tags to store other information, save the relations in a Hashtable.
To arrange the diagram, use some of the layout algorithm classes, e.g. LayeredLayout.
Dunkelelb
Reply #2 - Apr 25th, 2007 at 6:43am
thanks,
I beleave, thats enough Information for the moment
macleon
Reply #3 - Jun 20th, 2007 at 7:08pm
Dear Mr. Stoyan,
Do you have a sample done in c Sharp. I'm really having problem loading / binding the database from to creat tree diagram. I'm using mysql database buts that  nots a problem as I already manipulate it, but don't really quite sure on how or what type of db structure it support and how to connect them. Sorry for I am really a beginner.
Thanks for the help.
Reply #4 - Jun 21st, 2007 at 5:41am
Here is a small example:
[code]
Hashtable childToParent = new Hashtable();
SqlCommand cmd = new SqlCommand();
cmd.Connection = conn1;
cmd.CommandType = CommandType.Text;
cmd.CommandText = "SELECT * FROM dbo.TreeNodes";
SqlDataReader reader = cmd.ExecuteReader();
while (reader.Read())
     Box node = fc.CreateBox(0, 0, 40, 30);
     int nodeID = reader.GetInt32(0);
     node.Text = reader.GetString(1);
     int parentID = reader.GetInt32(2);
     node.Tag = nodeID;
     childToParent[nodeID] = parentID;
foreach (Box b in fc.Boxes)
     if  (!childToParent.ContainsKey(b.Tag))
           continue;
     fc.CreateArrow(
           fc.FindBox(childToParent[b.Tag]), b);
TreeLayout tl = new TreeLayout();
tl.Arrange(fc);
[/code]
macleon
Reply #5 - Jun 21st, 2007 at 2:23pm
Thank you for your quick reply.
These code really help me, even not what actually I wanted yet but I'm heading the right directions.
Thanks.  Grin
