Normal Topic Prevent Deletion of Flowchart Object (Read 2419 times)
mjweyland
Apr 26th, 2007 at 11:47am
Is there a way to absolutely prevent an object from being deleted from a flow chart?
I have some code on the key down event on the flow chart and this is stopping the event.  However, after the event is prevented if a user tries to multi-select nodes in a flowchart the object isn't selectable.
Ironically enough this is the effect I hope to achieve. I want to prevent specific nodes from being multi-selectable on a flowchart but still want to allow a group of items from being deleted from a flowchart possible.
Any suggestions is greatly appreciated.
_nodes is a collection object I use to management of the information back to the DB and _delete is a flag used on the deleting event.
	  While (fcMain.Selection.Objects.Count > 0)
		Try
		    Dim _o As Object = fcMain.Selection.Objects(0)
		    If _o.GetType.Name = "Box" Then
			  'attempt to delete the item from the collection
			  _nodes.Remove(fcMain.Selection.Objects.Item(0))
		    End If
		    _delete = True
		    fcMain.DeleteObject(fcMain.Selection.Objects(0))
		Catch ex As Exception
		    _delete = False
		    fcMain.Selection.Objects.Remove(fcMain.Selection.Objects(0))
		End Try
end while
Re: Prevent Deletion of Flowchart Object
Reply #1 - Apr 26th, 2007 at 12:00pm
Handle the BoxSelecting event and set e.Confirm = false to prevent users from selecting a box. Handle BoxDeleting to prevent them from deleting a box.
mjweyland
Reply #2 - Apr 26th, 2007 at 6:32pm
Already doing that.  That is what the _delete variable is handling.
after the e.confirm value has been set to _delete the event continues or aborts
If the event aborts the object then becomes unselectable.
Reply #3 - Apr 26th, 2007 at 7:44pm
Instead of
in the Catch block try setting
fcMain.Selection.Objects(0).Selected = false
or call
fcMain.Selection.RemoveObject(fcMain.Selection.Objects(0))
