Normal Topic IndexOutOfRangeException in RowHeaders.Clear() (Read 3273 times)
David Long
May 2nd, 2007 at 1:35pm
When I start a new Lane type diagram, I call the following code.  The trouble is I get a IndexOutOfRangeException when I call grid.RowHeaders.Clear();  Is this a bug in the DLL or am I not using it correctly?
DavidL
       private void InitialiseLanes()
           flowChart.ClearAll();
           flowChart.UndoManager.UndoEnabled = false;
           // Initialize grid
           Grid grid = flowChart.LaneGrid;
           grid.ColumnHeaders.Clear();
Re: IndexOutOfRangeException in RowHeaders.Clear()
Reply #1 - May 2nd, 2007 at 2:55pm
Try setting grid.RowCount and grid.ColunmCount to 0, instead of calling Headers.Clear().
Reply #2 - May 3rd, 2007 at 5:08am
This is definitely something that should not happen. Unfortunately I am unable to reproduce it here. Is it possible to send me the stack trace of the exception and/or the initialization code you are using before invoking this method?
Thank you,
David Long
Reply #3 - May 3rd, 2007 at 6:42am
The exception does not happen the first time I call this code, but the second time.  i.e. when there are actually rows and columns that I want to clear out in order to start a new chart.
David
David Long
Reply #4 - May 3rd, 2007 at 6:53am
BTW, Stoyan's solution gives the same exception.
David.
Reply #5 - May 3rd, 2007 at 7:14am
Any chance you can send me your initialization code (particularly the code which initializes the lane header collections before they are cleared)? The exception's stack trace can also be useful.
Thank you,
