Normal Topic Read Only (Read 2391 times)
CodingJeff
Read Only
May 7th, 2007 at 12:14am
I'm using this to display appointments only, is there a way to make the calendar (timetable view) read only, with only scrolling enabled?
Re: Read Only
Reply #1 - May 7th, 2007 at 5:01am
You can set Calendar.Enabled to false to disable all interaction with the control (including scrollbars). Alternatively, you can hide individual scrollbars by setting either Calendar.HScrollerVisible or Calendar.VScrollerVisible to State.Disabled.
CodingJeff
Re: Read Only
Reply #2 - May 7th, 2007 at 10:33am
I'd like to remove the ability to drag the appointments to other dates or times but would like to be able to capture a doubleclick on an appointment. Is that possible?
Re: Read Only
Reply #3 - May 7th, 2007 at 11:05am
You can set the AllowChangeStart, AllowChangeEnd and AllowMove properties of all items to false to prevent them from being modified interactively. Alternatively, you may handle the ItemModifying event and reject any item operation by settings Confirm to false.
