Normal Topic Size is duplicated by 3.77 factor (Read 3884 times)
ymoran00
May 9th, 2007 at 5:55am
I've set a size of a chart using the setDocBounds() method.
What I discovered is that any value I enter there is multiplied by 3.77.
For example - when I entered there 100x120 rectangle, I got on screen a rectangle of sizes 377x453.
Why is that?
Re: Size is duplicated by 3.77 factor
Reply #1 - May 9th, 2007 at 6:06am
The FlowChart has a MeasureUnit attribute, that specifies the logical unit of measure used for the size of the diagram and its elements. It is set to Millimeter by default, so calling setDocBounds(100x120) probably sets the size to 100x200 millimeters. You could call setMeasureUnit(MeasureUnit.Point), but then you will need to set the default item-size properties too, such as ArrowHeadSize, so they reflect the new unit.
ymoran00
Reply #2 - May 15th, 2007 at 12:41pm
I saw now that I forgot to answer that...
You were right, and it worked well after that.
Yoav
