Normal Topic a program about ShapeLibrary  and save&lo (Read 1635 times)
grayhound
May 15th, 2007 at 3:59am
1. I get the box sharp from my customer ShapeLibrary
	  protected ShapeTemplate GetSharpFromId(string sharpId)
		ShapeLibrary shapes = ShapeLibrary.LoadFrom(Application.StartupPath +
		@"\GraphicElements\SharpLibrary.shl");
		ShapeTemplate[] st = shapes.Shapes;   //if i don't put this sentence, the next sentence will return null
		return ShapeTemplate.FromId(sharpId);
2. Draw the Box
3. flowChart.SaveToString(true);
4. flowChart.LoadFromString(flString)
what's the program?
Re: a program about ShapeLibrary  and save&lo
Reply #1 - May 15th, 2007 at 4:58am
Is the shape library loaded when you call flowChart.LoadFromString(flString)? The shape definitions are not stored in the files/string saved using the FlowChart.Save* methods, so you will get a generic shape if the library is not loaded the next time you load the diagram.
grayhound
Re: a program about ShapeLibrary  and save&am
Reply #2 - May 15th, 2007 at 11:41pm
Thank you, the program has been solved.
anthoer question is :
if i don't use 'ShapeTemplate[] st = shapes.Shapes;' this sentence ,ShapeTemplate will not caontain the Sharp i designed.
and when i use that sentence, ShapeTemplate will contain my sharps.
but i did't use st anywhere
Reply #3 - May 16th, 2007 at 5:40am
I could not reproduce that problem. Could you email the SharpLibrary.shl file to support@mindfusion.eu so we can test with it?
Thank you.
