Normal Topic TreeLayout (Read 1912 times)
Dunkelelb
TreeLayout
May 16th, 2007 at 10:34am
hello,
I'd like know something more about automatic layout,
especially the TreeLayout.
I filled a diagram with some nodes.
afterthat I tried the treelayout. It seems to be very
a lean algorithm behind that.
around a half of the nodes don't change their postion.
I seems the results depends not of the links between the nodes but the actual position.
[now I'd like to know how to add screenshots:)]
Re: TreeLayout
Reply #1 - May 16th, 2007 at 11:04am
Please email the screenshot and the diagram xml file to support@mindfusion.eu. You cannot upload screenshots here, but only link to ones on your own server Undecided
Dunkelelb
Re: TreeLayout
Reply #2 - May 18th, 2007 at 5:58am
thanks, I will send a email.
I suppose I should also give relevant source code?
Re: TreeLayout
Reply #3 - May 18th, 2007 at 6:08am
Yes, the TreeLayout object initialization code will be useful.
Re: TreeLayout
Reply #4 - May 18th, 2007 at 6:36am
This should work better if you use either the IgnoreArrowDirection or ReversedArrows property. Otherwise the control considers the parent-to-child arrow direction to be the opposite to the one in your diagram.
