Normal Topic On Move event (Read 1058 times)
pelion
On Move event
May 17th, 2007 at 12:42am
Hi, I want to force a FitDocToObjects each time a chart item is moved on the FlowChart, so I tried capturing the SelectionMove event.
This, however, appears only to work when there are 2 or more items selected, not a single item (in my case this is currently a table, but will extend to other objects)
Is this functionality i'm seeing correct? Is there another event I can capture, or a property that will recognise a single object as a selection?
Re: On Move event
Reply #1 - May 17th, 2007 at 6:01am
You could enable the FlowChart.AutoSizeDoc property instead of calling FitDocToObjects from the SelectionMoved event handler.
Otherwise, you would have to handle some more events, such as BoxModified,ArrowModified, TableModified.
