Normal Topic How to set data? (Read 3835 times)
b.tani
How to set data?
May 17th, 2007 at 1:35pm
I have data but when I try to paste it to make a chart I encounter an error message (input string not in correct format). Please any one give me proper string format for this data.
Thanx
Re: How to set data?
Reply #1 - May 18th, 2007 at 12:09pm
Data properties that are simple arrays (not lists of lists) can be set in the property browser by typing the strings separated with commas. If the property is a list of lists, you must separate the contained lists with a semicolon. For such multidimensional arrays, you'd better use the editor that is opened via the "..." button.
