Normal Topic Comparision between Workflows (Read 1345 times)
Bhavan
May 29th, 2007 at 4:30am
Hai I am Working on Workflows now i need to show the comparisions between the two workflows (ie if i created a workflow and saved that one, again i reopen the workflow and done some modifications for the workflow and saved the workflow now i want to compare these two workflows)
is it possible in workflow and how to do it
Thank in advance
Re: Comparision between Workflows
Reply #1 - May 29th, 2007 at 5:28am
If you need to show the differences between two revisions of the same document, you could implement a change log and show the differences as a list of log entries recorded between some dates.
An easy way to implement that is to enable the FlowChart.UndoManager and handle the ActionRecorded event. In the event handler, create a log entry based on the command being recorded. Add a time-stamp to each record so you can compare the document revision dates with the log records times.
You can make the collection of log entries serializable and store it in the FlowChart.Tag.
Reply #2 - May 29th, 2007 at 5:32am
Another possibility is to assign unique IDs to each item.Tag. Then you can compare the document revisions by checking whether items with some ID exists in both versions, so you know if an item has been added or removed. If items with some ID exists in both documents, you can further compare their property values, e.g. Text, BoundingRect, etc.
