Normal Topic Remote a FlowChart (Read 1174 times)
meriturva
Remote a FlowChart
May 29th, 2007 at 7:24am
i'm developing a client/server application.
Every client has a different flowChart that change at runtime (color of shapes, text on box).
I have also one server that collect all raw data from client, now i would like to have a way to see all client's flowchart into the server application.
I'm starting to search a way, something like vnc embedded into my application, but i don't know if someone knows a better solution. The other solution is to export every time the client flowchart to bitmap and transfer it to server, but i don't like this solition, there is no way to make possible interaction from server to client.
Something about remoting in c#?
Meriturva
Re: Remote a FlowChart
Reply #1 - May 29th, 2007 at 8:29am
You could create a service (ASP.NET Web Service) project in your server solution and add a method that takes a string argument. The string will contain the diagram data passed by the clients, which you can load using LoadFromString().
Next, add a service reference to the client project, and when the user finishes editing the diagram, call the service method with a FlowChart.SaveToString() parameter value. That lets you receive the diagram data on the server, load it there, check its contents and structure, and possibly return some result to the client.
Using a service is probably the easiest solution, but you could transfer diagram strings and return results using any of the other .NET communication methods, e.g. TCP/IP connections, remoting or WCF.
