Version 1.2 of JDiagram provides the following new features:
* Overview component *
The Overview control provides a scaled-down view of a FlowChart contents and allows scrolling and zooming the diagram with the mouse.
* ShapeListBox component *
The ShapeListBox control displays a set of shapes defined via the Shape class. Shapes from the list box can be dragged to the FlowChart drawing canvas to create new boxes.
* Shape libraries *
Shape libraries are XML files that contain shape definitions. A library file can be loaded into your application using the ShapeLibrary class. The definitions loaded from a shape library are automatically added to the shared shapes collection and can be accessed through the getShapes and fromId methods of the Shape class, just as the predefined shapes.
* AnnealLayout layout class *
The AnnealLayout class implements the Simulated Annealing graph layout algorithm.
* Miscellaneous *
- The setImageUrl method has been added to the FlowChart class. It lets you load a background image from URL. When serializing the diagram, only the image URL is stored in the file.
- The getNodesAt method has been added to the FlowChart class. getNodesAt lets you find all nodes lying at the specified location.
- The setRotateText method has been added to the Box class. The method lets you enable or disable text rotation.
- The resizeToFitText method has been added to the Table class. The method resizes table's rows and columns so that the table cells fit their text.
An evaluation version is available for download here:
https://mindfusion.eu/JDiagramTrial.zip Registered customers are going to receive their upgrades shortly.
