Normal Topic Background of Overview (Read 6987 times)
ymoran00
May 31st, 2007 at 11:20am
Two questions about the L&F of the Overview:
1. Is there a way to change the color of the background of the overview - the section that's outside of the square? It's allways greay, and setBackground doesn't seem to work.
2. Is there a way to change the color of the square? To increase it's wodth?
Yoav
Re: Background of Overview
Reply #1 - May 31st, 2007 at 12:11pm
1. Use setDimColor().
2. That's hard-coded; we can add some properties for it in the next release.
ymoran00
Reply #2 - May 31st, 2007 at 12:17pm
1. As I seen, the DimColor refers to the part of the Overview outside the chart. What I'm reffering to is the part that is inside the chart but not visible (outside of the rectangle).
2. That would be great, thanks!
Yoav
Reply #3 - May 31st, 2007 at 12:26pm
Ok, our Java developer hasn't ported correctly the DimColor property from the .NET version. He'll fix this tomorrow, and will add some properties for the tracking rectangle borders.
ymoran00
Reply #4 - May 31st, 2007 at 12:27pm
Cheesy That would be great.
Yoav
Reply #5 - Jun 1st, 2007 at 9:20am
http://mindfusion.org/_temp/JDiagram.jar
adds a setTrackingRectPen() method that lets you set the pen for the view tracker rectangle. With the Pen object you can define color, width and dash style. And now the dim-color should work as advertised.
ymoran00
Reply #6 - Jun 3rd, 2007 at 4:50am
Thanks!
It now colors it white, and I can change the color of the tracking rect.
Yet with the new jar, something that looks like a bug happens: When I look at the overview, it seems that I can see there only what's inside the tracking rect. Outsed of it everything is blank. Do you know of this problem?
Reply #7 - Jun 3rd, 2007 at 7:43am
The dim-color covers everything outside the tracking rect. You must set it to a transparent color, with an alpha value less than 255, if you want to see through it.
ymoran00
Reply #8 - Jun 3rd, 2007 at 9:42am
It solved the problem - thanks!
