Normal Topic Change ANTI_ALIAS value fro text (Read 6040 times)
ymoran00
Jun 7th, 2007 at 7:55am
I'm looking for a way to paint the text of the Boxes with ANTI_ALIAS_OFF and the rest of the drawing with ANTI_ALIAS_ON.
I've looked if I can bypass the text draw method and plant these RenderHints, but as far as I can see - only solution is to use CustomDraw.Full and write everything myself (including the text drawing).
Is there another way to achieve it?
Thanks!
Yoav
Re: Change ANTI_ALIAS value fro text
Reply #1 - Jun 7th, 2007 at 10:13am
I guess we can add an AntiAliasText property, and you will just set it to false to achieve that.
ymoran00
Reply #2 - Jun 7th, 2007 at 10:16am
If you could - that would be great.
yoav
Reply #3 - Jun 11th, 2007 at 7:03am
This version adds a public void setTextAntiAlias(SmoothingMode antiAlias) method to FlowChart.
http://www.mindfusion.org/_temp/JDiagram.jar
The Overview tracking rectangle should work better as well.
ymoran00
Reply #4 - Jun 11th, 2007 at 7:44am
It looks great! And I saw you solved most of the Overview rectangle issues (if not all...).
Grin Thanks!
Yoav
BTW - how can I get a registered version of the Jar once you make such changes? Do I need to send an email to your support?
Thanks again,
Yoav
Reply #5 - Jun 11th, 2007 at 9:14am
I will send you a private message on the forum with a download link to the source code and the licensed jar.
Reply #6 - Jun 11th, 2007 at 9:28am
You should now see a "Hey, ymoran00, you have 1 message" line at the top of the forum page. The link is there Smiley
