Hot Topic (More than 10 Replies) KeepInsideParent and Rotation (Read 4413 times)
jstraylor
Jun 11th, 2007 at 11:25am
I have a flowchart that I create with a bottom bounding box (think of a fenced compound, the bottom box defines the area inside the fence).  I then create a new rectangular box, attach it to the bounding box, and set it to KeepInsideParent.  When a user then rotates the box it no longer obeys the bounds of the parent correctly, it keeps itself inside based on its ORIGINAL bounding rectangle rather than the new bounding rectangle created by the rotation.
Am I doing something wrong, or do you have an idea on how to make this work?
Jeff
Re: KeepInsideParent and Rotation
Reply #1 - Jun 11th, 2007 at 12:59pm
It seems we have omitted checking the RotationAngle. Until we fix this, you could handle BoxModifying and cancel the modification if the bounding rectangle of the rotated box is not entirely inside the parent's bounds.
jstraylor
Reply #2 - Jun 11th, 2007 at 1:29pm
Thanks Stoyo.
Are you going to fix both the 4 series and the beta versions??  We're still using the release 4 series.
Jeff
Reply #3 - Jun 11th, 2007 at 3:41pm
Hi Jeff,
We will send you a fixed 4.3.1 dll in a few days.
jstraylor
Reply #4 - Jul 19th, 2007 at 12:03pm
Did this get fixed and I missed it?
Jeff
Reply #5 - Jul 19th, 2007 at 3:39pm
That's not fixed yet.
jstraylor
Reply #6 - Sep 27th, 2007 at 3:41pm
Stoyo,
This problem is becoming an issue for us, is there any way that it can/will be fixed soon??
I would really like to not have to implement a workaround for it.
Jeff
Reply #7 - Sep 27th, 2007 at 5:20pm
This should have been fixed in the latest release. We can also port the fix to V4.3.1  if you don't wish to move to version 5 yet.
jstraylor
Reply #8 - Sep 27th, 2007 at 5:27pm
It would be most excellent if the fix could be backported to 4.3.  We are in the middle of a field trial of our software and really don't want to make a change as large as the move to version 5 until we are ready to make the same upgrade to other components.  (Version 2.0 of our software will be based on Flowchart.NET 5)
Reply #9 - Sep 28th, 2007 at 4:34am
Hi Jeff,
I have sent you a PM with a link to download the updated licensed dlls. You can open the private messages area from the link at the top of the forum page.
jstraylor
Reply #10 - Sep 28th, 2007 at 12:05pm
Stoyo,
OK, they ALMOST work.  While rotating the bounding rectangle seems to be updating just fine, but once I stop rotating and try to move the object it appears that the ORIGINAL bounding rectangle is being used to check for KeepInside.
Could you look at this for us??
Thank you,
Jeff
Reply #11 - Sep 28th, 2007 at 12:25pm
It works fine for me. Could you email me a saved flowchart file, so that we can test that with the same settings as yours?
Reply #12 - Sep 28th, 2007 at 12:59pm
Now I've seen that the constraint is not applied when dragging a multiple-selection. Is that the problem?
Reply #13 - Oct 4th, 2007 at 8:11am
I have sent you updated assemblies which should work better with KeepInsideParent + rotation + multiple selection, in case that was the problem.
