Normal Topic default flowChart properties (Read 1857 times)
Dunkelelb
Jun 12th, 2007 at 6:38am
hello,
for a special flowchart I got to change a default value
(while click+mouse move 'creating unconnected Arrow' insteadof creatingNode).
so I implemented two buttons
-->drawing Arrow
-->drawing Nodes
but 'drawing Nodes' lets make me nodes everywhere;
its not the behavior as it is in the default flowchart
(mouseclick+moving above a node make a new node insteadof making an arrow)
-->do I have to implement every standard property again or exists there a default collection?
very thanks
something different:
in the developers guide you could spent some words more about DummyNodes (in the DOC it is only a word in the flowChart-Class)
Re: default flowChart properties
Reply #1 - Jun 12th, 2007 at 6:59am
How have you implemented the Draw Nodes button? By setting flowhart.Behavior to CreateBox? Setting flowhart.Behavior to FlowChart should return the default behavior of creating arrows when drawing from a node.
Dunkelelb
Reply #2 - Jun 12th, 2007 at 10:06am
you're right:D.
in the winForm editor you can switch
AllowInPlaceEdit() for a flowChart.
normally I want editable boxes.
for special cases
I want  special special movable but not editable Box
(that means locking a box isn't the right thing)
what is the solution for that problem?
thanks
Reply #3 - Jun 12th, 2007 at 11:31am
There is a BoxInplaceEditing validation event raised when the user double-clicks a box. Set e.Confirm = false to prevent editing some boxes.
