Normal Topic Collapsing Nodes (Read 1990 times)
asloan
Collapsing Nodes
Jun 12th, 2007 at 4:18pm
Is there a way or an option in FCX, that if I have a branch of a diagram that is border aligned, and I collapse a node that is say in the middle of this branch that the nodes below the collapsed node move up to fill the empty space that is now there because the node was collapsed?
Alan
Re: Collapsing Nodes
Reply #1 - Jun 12th, 2007 at 5:20pm
You could handle BoxCollapsed and run the tree layout again starting from the collapsed box' parent. The DirTree example works in a similar way.
asloan
Reply #2 - Jun 12th, 2007 at 8:00pm
That did the trick!
Alan
