Normal Topic Load arrow from wml file (Read 1748 times)
alesdario
Jun 14th, 2007 at 6:36am
Hi stoyo.
I save control points of a bezier' arrow in a xml file. The arrow look like straight line.
When i reload arrow from xml file
Arrow.ControlPoints.SetAt(index, Point);
where Point is the point i read in xml file.
But arrow's control point are not at the same position, but some is shifted on the left, some is shifted on the right?
Why?
Re: Load arrow from wml file
Reply #1 - Jun 14th, 2007 at 6:48am
They might be saved incorrectly. Check if the point coordinates from the XML file form a straight line. E.g. create a straight Bezier arrow starting from 0, 0, save it with your code, open the resulting XML file, and verify whether the x/y ratio of all point is the same.
In addition, make sure the point coordinates aren't converted to integer values when saving or parsed as integers when loading. That might add some offset, depending on the MeasureUnit that you use.
alesdario
Reply #2 - Jun 14th, 2007 at 7:26am
Tanks.
