Normal Topic Arrow.SetOrigin throws exception (Read 3092 times)
koosala
Java Happens
Jun 19th, 2007 at 3:56am
I was trying the following lines to first create two boxes and then create an arrow. Then set the origin of the arrow to the first box
Box box = new Box(flowchart);
box.setBounds(new Rectangle2D.Float(100, 100, 100, 100));
flowchart.add(box);
Box box2 = new Box(flowchart);
box2.setBounds(new Rectangle2D.Float(300, 300, 100, 100));
flowchart.add(box2);
Arrow test = new Arrow(flowchart);
test.setOrigin(box);
It threw an exception
java.lang.NullPointerException
at com.mindfusion.jdiagram.Link.b(Unknown Source)
at com.mindfusion.jdiagram.Arrow.setOrigin(Unknown Source)
at OrgChartTest.init(OrgChartTest.java:71)
at sun.applet.AppletPanel.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
I know both the origin and destination nodes can be specified in the constructor of the arrow itself, but I want to be able to dynamically link arrows around, even during its creation.
So, a bug?
Re: Arrow.SetOrigin throws exception
Reply #1 - Jun 19th, 2007 at 5:21am
Try using the Arrow(Point2D, Point2D) constructor to create an unconnected arrow. setOrigin should work fine after that.
koosala
Java Happens
Reply #2 - Jun 19th, 2007 at 7:20am
Works, thank you.
But is there a reason the other mechanism didn't work?
Reply #3 - Jun 19th, 2007 at 9:43am
That constructor is supposedly used only when drawing arrows interactively, but I don't know why it is public.
