Normal Topic TwelveHourFormat Problem (Read 4100 times)
Nikemare
Jun 20th, 2007 at 2:20pm
ctrlCalendar.TimetableSettings.StartTime = StartTime;
ctrlCalendar.TimetableSettings.CellTime = CellTime;
ctrlCalendar.TimetableSettings.EndTime = EndTime;
ctrlCalendar.TimetableSettings.TwelveHourFormat = State.Disabled;
ctrlCalendar.CurrentView = MindFusion.Scheduling.Compact.CalendarView.Timetable;
If i set values for StartTime, CellTime and EndTime the TwelveHourFormat is used. If i don't set values for StartTime, CellTime, EndTime the 24h Format is used.
Nikemare
Re: TwelveHourFormat Problem
Reply #1 - Jun 21st, 2007 at 7:16am
Some additional info:
Starttime = 7:05
Celltime = 55 Minutes
EndTime = 23:35
Reply #2 - Jun 21st, 2007 at 8:29am
Thank you, our developers will look into this ASAP.
Reply #3 - Jun 25th, 2007 at 9:46am
Try to set the TimetableSettings.GeneralFormat to "H:mm tt" as well. It appears that the TwelveHourFormat property is only used when the divisions in the timeline are rounded. Otherwise the GeneralFormat property is used.
Nikemare
Reply #4 - Jun 25th, 2007 at 11:00am
Thank you, this has solved my problem!
