Normal Topic Visio Export and Import (Read 2319 times)
willod
Jun 23rd, 2007 at 8:30pm
I am trying to use the Visio import and export in FlowchartX Pro and cant get it to work! Is there any VB sample code available?
Thanks  Smiley
Re: Visio Export and Import
Reply #1 - Jun 25th, 2007 at 6:59am
Are you using the .NET or the ActiveX control? When exporting to Visio, the VisioExport.vxt file must be in the same folder where your executable file is. In addition, the MSXML runtime must be installed on the systems where the ActiveX import/export components are used.
willod
Reply #2 - Jul 2nd, 2007 at 4:59pm
Hi Stoyan
I am using the ActiveX version. I have the VisioExport.vxt in the .exe directory and a reference to MSXML.
If i use the folowing code I do get a .vdx diagram created (a blank one as expected).
Dim Visio_flow As New FcxVisioExportLib.VisioExporter
Dim flow As New FLOWCHARTLib.FlowChart
Visio_flow.ExportVDX(flow, "D:\test.vdx")
But if I try and refer to my existing flow chart such as
flow = AxFlowChart_Process_Flow
I get an 'Specified cast is not valid' error.
If i refer to the flowchart directly such as
     Visio_flow.ExportVDX(AxFlowChart_Process_Flow, "D:\test.vdx")
I get a 'No such interface supported'!
So the export seems to be working ok until I refer to my existing flowchart!
Thanks for your help
Will
Reply #3 - Jul 3rd, 2007 at 5:30am
Hi Will,
Is AxFlowChart_Process_Flow a FlowchartX instance on a VB form?
This is a test project we use to test the export and import components, please check if it works your system:
https://www.mindfusion.org/_temp/VisioTester.zip
