Normal Topic Visio Import example (Read 2319 times)
Frankinstien
Jun 29th, 2007 at 5:06am
Does anyone know where I could get a code example of a Visio import?
Frank
Re: Visio Import example
Reply #1 - Jun 29th, 2007 at 5:56am
Frankinstien
Reply #2 - Jul 8th, 2007 at 12:20pm
Stoyan,
Thank you for the example. However I am unable to get it to work. When I try and import a .vdx file I get a blank screen. I have placed the VisioExport.vxt in the project and bin directories but it still will not import. ???
Frank
Reply #3 - Jul 9th, 2007 at 5:47am
Could you email me the .vdx file?
Reply #4 - Jul 10th, 2007 at 7:13am
An XML attribute that the importer considers mandatory (page\unit) is missing from that file, and the importer just exits. We have changed this to use default units when the attribute is missing, and the page imports ok. This change will be available in Flowchart.NET 5.
However the importer still does not recognize any of the electrical symbols used in the drawing, so they are imported as rectangles. You will need to handle the VisioExporter.BoxImported event and map the imported Visio shapes to your custom Flowchart.NET shapes.
