Normal Topic Groups (Read 1490 times)
MagnusSpeychal
Groups
Jul 6th, 2007 at 10:35am
Hi
When adding a box to a group, what is the purpose of attaching the box to the corner of the master object? The attached box does not change its position during this operation.
Best regards,
Magnus
Re: Groups
Reply #1 - Jul 6th, 2007 at 12:19pm
The attached node will be anchored to the specified corner and always keep the initial distance from it. This is useful when you allow the master node to be resized. If the master can only be moved, it doesn't matter to which corner you attach subordinate items.
