Normal Topic 24 hour clock (Read 2841 times)
Aliza
24 hour clock
Jul 9th, 2007 at 5:21am
My calendar has a bottom time line which displayes the hours of the day. Right now the hours are displayed according to  a 12 hour clock. I would like the hours to be diplayed by a 24 hours clock (wrap back to 1:00 after 24:00 and not after 12:00). Is there anyway to do this?
Thanks in advance,
Aliza
Re: 24 hour clock
Reply #1 - Jul 9th, 2007 at 6:26am
Try setting the Format property of the BottomTimelineSettings to "h:mm".
Aliza
Re: 24 hour clock
Reply #2 - Jul 9th, 2007 at 9:57am
I did. Still shows a 12 hour clock.
Re: 24 hour clock
Reply #3 - Jul 9th, 2007 at 11:13am
My mistake. Try the following format instead: "H:mm". In general, the Format property uses the same specifiers as those acceptable by the DateTime.ToString(string) method. Check the MSDN Library to see what other format specifiers are available.
Aliza
Re: 24 hour clock
Reply #4 - Jul 9th, 2007 at 11:37am
H:mm did it:) Thanks!
