Normal Topic getNodesIn(Rectangle2D.Float) anyone? (Read 4600 times)
koosala
Java Happens
Jul 11th, 2007 at 8:40am
There is a function FlowChart.getBoxes() which gets all the boxes on the flowchart. Now, in very interactive diagramming, where we write logic on mouse moves/drags using this function turns into a lot of processing, especially if there are like 1000 boxes spread over the canvas.
Can a similar function be provided where the search scope could be reduced to a specified rectangle so that we deal with fewer objects?
I know there is getNodesAt(Point), I was thinking maybe getNodesIn(Rectangle2D.Float)
Praveen
Re: getNodesIn(Rectangle2D.Float) anyone?
Reply #1 - Jul 11th, 2007 at 9:04am
You could call Rectangle2D.contains(aBox.getBounds()) to determine which boxes are inside the rectangle, and then process only them.
koosala
Java Happens
Reply #2 - Jul 11th, 2007 at 9:18am
Hi Stoyan,
The Rectangle2D.Contains method would return a true or a false.
So, I will have a Rectangle2D object with me. Then I will have to pass each of the box's bounds to that guy to check if the rectangle contains it.
So, I will have to loop through each of these boxes on the flowchart.
I hope I didn't understand your explanation wrong.
I was just wondering having a trimmed down function that was something like Flowchart.getNodesIn(Rectangle 2D.Float)
Praveen
Reply #3 - Jul 11th, 2007 at 10:31am
Hi Praveen,
That's correct. We can add a function as well, but not before we release version 1.0.1 of the control.
koosala
Java Happens
Reply #4 - Jul 12th, 2007 at 2:50am
That's alright. I was wondering if you'd internally use a more optimized method than searching through all the boxes. If that is how your API would be doing it anyway, I will include that code myself right now.
Praveen
Reply #5 - Jul 12th, 2007 at 5:04am
At this time we can only implement it using a linear search. Our developers are working on R*-tree implementation for storing diagram items that will improve performance for large diagrams, but it won't be available for at least a couple of months.
