Normal Topic Layout algorithm ignores Box/DiagrammNode bounds (Read 3160 times)
due
Jul 12th, 2007 at 10:46am
I use FlowChart.NET to create organization charts automatically. In this case, boxes with different sizes, caused by different text sizes, are required. So, it is not possible to determine one unique box size. To arrange the boxes I use the layout algorithms of FlowChart's Pro Edition. Unfortunately, these algorithms ignore the size of nodes!?
For example, the layered layout algorithm provides a NodeDistance property to specify the distance between adjacent nodes (in a layer). Obviously, this value will be interpreted as the distance of node's midpoints (center of box). That's the reason why the box size will not be considered and causes an ugly appearance (overlapping boxes). How can I define a box gap (distance among boxes)?
Re: Layout algorithm ignores Box/DiagrammNode boun
Reply #1 - Jul 12th, 2007 at 11:26am
Currently only the TreeLayout considers the size of nodes while arranging them. You could use it instead of LayeredLayout to arrange the organizational charts.
due
Reply #2 - Jul 12th, 2007 at 12:00pm
The result of TreeLayout is disappointing.
I guess the TreeLayout does not fit for charts with more than one root node, e.g. two or three chief executive officer.
Do you implement this essential feature (at least for LayeredLayout) in Version 5?
Reply #3 - Jul 12th, 2007 at 12:42pm
Well, that's not exactly a tree. We'll try to implement node size processing for the layered layout while version 5 is in beta tests.
due
Reply #4 - Jul 16th, 2007 at 5:06am
Thank you for your quick reply.
Now, I am looking forward to using version 5...
due
Reply #5 - Oct 11th, 2007 at 12:05pm
After updating to version 5 the layered layout algorithm still have the same behavior (ignores node size) ???
Or did I miss something?
Reply #6 - Oct 12th, 2007 at 4:57am
Sorry, we haven't implemented this yet.
due
Reply #7 - Oct 12th, 2007 at 9:21am
Sad
When is this going to be available?
(at end of October?)
Reply #8 - Oct 12th, 2007 at 12:02pm
I don't know. We'd like to have this feature too, but it's not that easy to implement.
We have recently added support for different node sizes to the AnnealLayout. I can send you a preview build of version 5.0.1 if you wish to try it.
Reply #9 - Oct 16th, 2007 at 8:20am
This version contains an updated LayeredLayout that considers the nodes sizes:
https://mindfusion.org/_temp/fcnet501_pre.zip
The implementation is still in experimental stage, so that's disabled by default. To try it, set
LayeredLayout.IgnoreNodeBounds = false;
